Tecumseh engine surging
joe4356
Acquired a toro recycler with a 6.5 go tecumseh engine LV195EA that was over revving I adjusted the governor it runs at a much better rpm now but surges a bit any suggestions?
joe4356
Also
Also when I did make this adjustment the self propel stopped working
nbpt100
Do you have a tachometer to check the RPM? In addition to cleaning the carb make sure the air intake is not sucking in air from a bad gasket. start with making sure the bolts are all tight. Not gorrilla tight but snug tight.
