Guggenheim24
- Jun 10, 2018
- 9
Engine is off of an older Toro Recycler (not sure of year of mower itself) When first starting the motor from cold, it will run for about 3 seconds and die. It will do this same thing about 4 more times before I can get it running smooth. Every time it dies, I reprime it, pull the cord and it fires up. If I prime it right before it dies, it will stay running. After about 4 times, I can finally get it to run continuously, but it builds revs really slowly, and won't be at full power until like 2 minutes of warming it up. Once it warms completely, it starts and runs with no issues. It seems like it's starving for fuel when the engine is cold. We've rebuilt the carburetor, replaced the emulsion tube, along with the O-rings on it, new air filter, new gaskets on the intake. Gas is ran out every fall, and I use stabil throughout its running season, so fuel degradation during and after the season is not an issue. It did this issue before we tore the carb apart, and still does after the rebuild of the carburetor. Any ideas? Thanks. (I copied every number off the info plate, some may not be necessary, just wasn't sure)
Engine Information:
Model: LEV120
Spec: 361560B
DOM: 02294DA1059
Engine Family: 2TPXS.1951BC
Disp: 195cc
Engine Information:
Model: LEV120
Spec: 361560B
DOM: 02294DA1059
Disp: 195cc
