Tecumseh Carburetor Issue
Booshcat
Hi guys,
I have a Tecumseh Enduro 5HP horizontal shaft engine on my Cyclone Rake, that drives the vacuum impeller.
It starts after a few pumps on the prime bulb, but will die ou quickly after.
I can only keep it running by holding the primer bulb in to its fully depressed condition (not pumping). I suspect a leak in the bulb, but there is no damage or hole visible. Does anyone have any other reasons why this would occur?
I tried to locate an engine plate, but no numbers are visible, they may be on the side facing the impeller housing.
Thanks!
Fish
Remove the bowl nut and bowl and take a peek. Inspect the nut {jet} and thoroughly clean out all of the little holes/passages.
Booshcat
Thanks, I'll drop the bowl and take a look
I found the numbers. It's an OHH50-65
OH195EA/OH195EP.
Booshcat
Thank you Fish!
That worked, blew it out with compressed air, and it's running like a champ.
The engine only gets used for a few hours each fall picking up leaves.
Fish
Thank you Fish!
Yeah, sitting with old gas gets those jets gummed up. Glad it worked for you. I actually leave that nut turned back a hair so the fuel will drip on out before I put it up for the year.
VegetiveSteam
Just my 2 cents. When I know I'm about done mulching leaves for the year I switch from pump gas to Tru-Fuel or VP Fuel for the last couple of tanks. It's a little expensive but nothing gums up and everything starts next year without any issues.
