Do you SEE fuel jumping up into the carb venturi out of the brass emulsion tube? You have to look INTO the bore of the carb. When you hit the primer a little fuel fountain so to say will jump up with every pump.Put plug back in, pumped primer 3 times , tugged away at pull start, just like before ... NOTHING!
If you have spark at the spark plug boot end and are grounding to CLEAN UNPAINTED metal on the block, spark is good.when I checked for spark I put plug in the end of the wire put it close to body of mower , I used my Dewalt to spin motor at the fan. Got good robust spark ! Could it still be the plug ?
For sure. Do NOT shop on amazon nor ebay. Pirated plugs are all over town. NGK's are the worst.I have had bad spark plugs. Get a new one from your local auto parts store like AutoZone, Napa, O'Reillys etc., and not online.
All of this would be your step #1 to try. Should of been done on page 1 post number 1. Fuel related issues are the highest faults in mower engines.Tecumseh RUNS ! Before I was going to do any more Diag. I thought I'de go back to simple . Found my can of real starter fluid , put screw driver down carb ( NO THROTTLE ON THIS ) shot some down the throat. Gave it a couple of tugs ! Started right up !
Don't really know if I didn't anything to make it start other than the squirt of fluid, but it starts !
Thanks to everyone who tried to help !
