Hello forum members,
Engine info:
I have a Tecumseh model 143-943814-4061k engine on a Craftsman Eager-1 push mower model 944-364160 that wont start.
What happened:
Last week 3/4 of the way through cutting the lawn the mower stopped running. It made a muffled pop/backfire sound and just stopped. It was on level ground, hadnt hit anything, minimal amount of grass being cut. Tried to restart, but on pulling the cord it makes a wheezing sound thats coming from the crank case breather tube. It sounds like a goose gasping for air through a straw. The pull cord also feels a bit odd, like the piston is sticking or something.
I have had the mower make a single small pop of an ignition a couple of times after many very hard attempts at pulling the starter cord. It hasnt started properly yet.
What I tried to fix:
So I checked for spark by grounding the plug to the head and pulling the starter cord, and its strong and consistent. I checked compression with my finder on the spark plug hole and it feels strong. I checked the carb, and found the float has liquid inside so I replaced the float, needle, seat, and gaskets for the bowl/bottom jet.
Nothing. So I pulled the flywheel and checked the key. Its absolutely perfect. So I pulled the head. For a 20 year old mower, not bad. No pitting, moderate carbon build up that mostly came off by carb cleaner. Both valves rotate freely, not sure if thats normal but they seem to seat properly. Though when turning the engine over there was a couple large drops oil on each stroke that got pushed up by the piston. Not sure if this is normal? Seems like worn rings letting oil through.
Still wont start. It still makes the wheezing sound from the crank breather hose, and the engine feels lumpy when the starter cord is pulled.
Any ideas?
Engine info:
What happened:
Any ideas?
