I have a Techumseh vertical V60 motor that goes to a Big Mow. I am having issue with the generator portion in that I can't get any spark out of it. I have managed to get some spark by placing the magnets onto the flywheel where I think they belong. I have no experience with these engines. I've replaced the condenser, the magneto (plastic part with the coil inside and plug wire), and the points. I've adjusted the points to .20 or .020 or whatever it's supposed to be.
I've got to the point where I can actually feel some electricity thru the wire and ground, but when I do a spark plug test, there's nothing. Any suggestions? Here is a pic of the setup. Thanks!
FYI, thanks for the lame pic size limitation. Who does this?
