- Sep 7, 2024
- 3,274
The 3 fuel lines should be connected as follows:I replaced the carb, fuel lines, and bulb. Like a fool I do not remember nor did I write down how everything hooks back up. The carb has 1 nipple on the top and a straight and curved nipple on bottom. The bulb has three nipples with a shorter one and a longer one on the outer circumference and a longer one in the middle. PLEASE HELP!
- The (clear) main fuel line with the filter (filter inside the fuel tank) goes to the bottom of the carburetor (or the elbow shaped nipple).
- The (clear) fuel intake line runs from the top of the carburetor (straight nipple) and goes to the short post on the back of the primer bulb.
- The return line (blue) comes from the long post on the back of the primer bulb and goes into the bottom of the fuel tank.
