Tb225 tiller puzzle
1967
Hello all,
Got 2015 tb225 tiller for peanuts. Basics are covered: got spark, put new carb(2!), new lines and plug. Only sputter when starter fluid sprayed in carb. Primer fills, but don't seem to see gas coming out of carb inlet. What am I missing? Done my share of carb swaps and this is a 1st for me. Thanks in advance!
It don't supposed have coming out the main nozzle until are cranking it.
Check the engine compression, It must be 100 psi or higher for the engine to even try to run. IF below 100 psi it is toast.
Thanks.
Got it going.
Don't know why, but new fuel line was already split. Replaced it, new filter, started right away. Will remember this one!
