TB2044xp weed eater
will6809
Hello everyone i need some help with my weed eater. My pull string broke and i cant figure out how to get the reoil out to retie it.
Any help would be appreciated.
Thanks
If the cord is between the engine & the shaft, then you have to pull the entire thing apart.
First pull the shaft out then the clutch cover .
On some you even have to remove the clutch as well to get the the starter
