Tank M54 spindle bearings? (tapered bearing)
cbs123
Hey guys,
I'm looking for a tapered bearing for a tank M54 cub cadet. It's measuring approximately 1.245 id and 2.44 od. I believe the spindle part # is 918-05125, but it's around $265. Looking for just the bearings. The breakdowns I've found don't show just the bearings. Thanks
Here I go again! How about you supplying us with the model and serial numbers for your unit off the ID tags. It would sure help us help you. That way it will save us time and we really, really , really hate taking stabs in the dark as to if we are giving you good suggestions.
Take out one the taper bearings and look for the number engraved on it. It should start with LM. Also measure the OD the cup. The problem will be the seals.
cpurvis
Agree with StarTech. Tapered roller bearings' cups (the race) and cones (the bearing) have their part number on them.
