dshoffman77
I'm taking it back to the dealer, but thought I'd run it by here as well.
Brand new Tank L60, less than 5 hrs on it. I start it, cut the grass for a bit... Oh look, something in the yard so I have to get off the mower to go pick it up. Shut off the blades, set the brake, throttle down, turn off the mower. Pick up item... get back on mower, turn key.. Nothing.. no click of a relay, or anything. So, I check the brake, make sure PTO is turned off, put key back in and I hear the relay click by turning key, but when I turn to crank engine, nothing... doesnt even try to turn engine. I sit, and look for a while making sure the brake is set, and that I'm on the seat properly... I turn the key again.. it starts...
It does this almost every cut.
Thanks, in advance, and once the dealer resolves it, I'll post my findings.
Dave,
Dave,
