I did and downloaded and printed the whole manual. It does really address my problem, why the mower is out of gear even when the by-pass valve is in. What can I expect when I seperate the housing? What should be checked once I do? Has this problem not occurred with anyone else?
I THINK you meant... it does NOT really address the problem... anyway, I personally have never worked on one of these Hydro-Gear trannys, I can only assume that while the unit was still in the mower you checked the belts ..
pulleys, fluid, and specifically .... the controlling linkages ?? Now that the unit is out I would at least check the BY-Pass control linkage and the return to neutral assy. here are a few links to some you-tube vids of trans repairs that may give you some insight as to whats awaiting you during your repair . Might I suggest... you take MANY , MANY, MANY pictures during the DIS-assembly... process ..they will be VERY valuable later , during inspection and RE assembly..
https://www.youtube.com/watch?v=7YqGwDqIrPc
https://www.youtube.com/watch?v=ia6kIcGY0IU
https://www.youtube.com/watch?v=o46FYudtAuc
the last one has 4 parts to it ...scroll through that video to locate the other 3 ......
Patience .. it takes time to go through something new the first time .. Boobala
