Can you please help me determine the make and number of the Hydro-Static Transmission, on my Kubota Mower, Model T1770-A, purchased new in 2007.
The engine is the Kohler CV17 V-Twin and the deck is the 44" three blade .
The company making the hydro 亡tatic transmission, is it Kubota or another company.
The problem I am having is the Nylon Barb Transmission fitting on the top of the case, for venting the case, got broken off. As I would like to use brass instead of the original Nylon, I have tried several brass fittings with a 1/2" barb, that fit into the ス ID rubber hose which is one foot long, with the vent clamped into the other end. It does not appear the threads are a correct fit. Can u tell me, if I should I be looking for a Metric fitting thread?
I appreciate anyone getting back with help on my question.
jamesemu
jamesemu
