hotshot Member Joined Dec 26, 2011 Messages 22 Feb 15, 2012 #1 I have a 70 something landlord system 7010 and the key doesn't shut it off I have to pull the plug wire. There is also an empty spade connector on the switch any help would be greatly appreciated.
reynoldston Lawn Pro Joined May 23, 2011 Messages 5,705 Feb 15, 2012 #2 Negative power to the coil turns off tractor. Maybe a loose or broken wire to a ground on the chassis some place?
