BWH
- Mar 22, 2011
- Threads
- 32
- 352
I was meaning to add my experiences with hydraulic oil I am in the electric utility field we have had to deal with slow operations in sub zero temperatures over the years in basket trucks. A good number of years after we gave up on aircraft fluids in the hydraulic systems due to the lack of lubercation in the pumps we switched to synthetic hydraulic oil, it was not as good as the aircraft fluids but pumps were too expensive to replace plus the synthetic was twice as flowable and if you can imagine 70 foot of hose going up the boom and 70 foot going down would make the boom extreemly slow.
The accidental find in this case was the great properties of this oil in extreem heat. If you have never been around a basket truck you have no idea how hot the circulating oil at 3500psi can get! Put it this way a hydraulic impact gun running at the boom tip on a 95dg. day is to hot to hold onto using peterolum oil but using synthetic it is still fairly warm but the impact tool is usable wearing gloves. I am told by the tech's in the hydraulic shop its all about friction. Just my observations for what their worth.
