Repairs Swapping motor 18 Kohler with same
Jimmy's
How do I get clutch off shaft on belt drive.? Is there a special wrench keep shaft from turning and is it counter clock wise to remove bolt? This is a toro work horse 18 Kohler
Without an impact wrench, it can be tricky. Just put your wrench on the bolt, and smack the wrench in quick strokes to the left until the bolt loosens up, it will come off.
