Swapping Hustler decks
dbjcon
I have two nearly new 2017 Hustler X-ONES. One has a FX730 Kawasaki with the 60" Deck, other one has the FX850 Kawasaki with a 54" deck. Can I swap the two decks with NO PROBLEMS for obvious reasons?
DBJ
If the tension arm is on an adjustable bolt then it will just be a matter to tightening it
If the tension arm spring goes between 2 fixed points then you will need a shorter belt .
The way to verify if there are no major changes needed is to go to a web site and download the parts manuals for the X-One series
Then look to see if the deck hardwear has the same parts numbers for the deck sizes you are looking at.
Remember to check the deck & the deck lift
Last time I had to do something similar with Hustler every thing was the same .
They are a small company so usually they would only make 2 or 3 frame sizes and that is what determines the lifting gear.
