- May 6, 2010
- 12,049
Look at the number of vehicles that require removing the intake manifold to replace the spark plugs.Don't you just hate the way they pack some of engines and other parts in where you got to half take the equipment apart just to replace the bad part. I recently had to pull an engine just to replace the remote starter solenoid. Or like the Gravely I did two weeks ago where the engine had be removed just to replace the main starter cable as a hydraulic hose was in the way and starter could not be removed. All because of a cheap connector Gravely used.
