You check the valve lash clearance and you tightened one up? Did I understand that correctly? What did you measure for valve clearance? How did you adjust the clearance?Also I did put the O ring in there between the carb and the block. It made no difference. I checked the valve spacing, it seemed pretty good. One was a tiny bit loose, I tightened it up, no change.
