Hi to everyone on the forum. This is my first post here.
I have a Husqvarna ride on mower with a Kohler PS SV730-0022 engine. Twin cylinder, gasoline, 25hp.
It will not start & I have removed the air filter and I can see fuel down both sides of the air intake (if that makes sense). When I shake the mower this fuel sloshes around & some has actually spilt out the top of the air inlet.
I assume that whatever regulates the fuel flow in the fuel pump?? is no longer doing its job & fuel is just running into the carby.
Can anyone give me a heads up on what to do next or is it a job for the mower shop?
Cheers from Australia
