Super Bronco 50 XP 2018
I replaced the PTO switch on my Troy Bilt super bronco 50 xp due to the blades shuts off randomly and that did not solve the problem, and I have checked the belt and there is no slippage. so I am considering changing out the solenoid but I cannot find it's location, I taught it would be close to the PTO switch under the dash cover, anyone knows where it would be located.? Thanks.
It is locate in the dash harness. Relay PN 925-1648A. You won't find it listed as an available part on the mower's IPL.
Also the connector terminals at the PTO switch, Ignition switch, and the PTO itself. They can become loose due to broken hinge joints.
