sunstrand
blueeyes
On a sunstrand hydro is their suppose to be shims in the top right shallow hole which I believe is the implement lift. Wht I am asking is when I dismantled mine did not see any shims, what I have read is that their should be Is this correct? if so where or how thick is shims? THANKs:confused2:
reynoldston
Through the years as a mechanic when I found shims they were there for a reason. Something needed clearance by a few .001. This is measured by a dial. I just don't see how anyone on a forum can give you a measurement like that?
