Conveyorbelt
- Aug 20, 2020
- 2
- 6
Second post!
After I got the blade adaptor off the bottom of my motor (which is a Briggs, model 100802 0124 B8), I am still unable to slide the sump down any further than it has already come. When twisting it, it twists a certain distance one way and then hits something. In the first picture, I tried to cut through the oil seal in case that's what is causing the inability to pull it off, so that is why it is torn up. In the last picture, there is what looks like a sheared off bolt, but I can't tell, and when I look inside as best as I can, it doesn't seem to be connected to anything. Is there a certain technique I should be using to get this off, or is it supposed to pull straight off the crankshaft? I know I havent done a great job explaining this, so if you need any more information, photos, or videos, ill do my best.
Thanks
Conveyorbelt
Thanks
Conveyorbelt
