bcliquidforce
- May 14, 2022
- 1
- 3
I have a Craftsman lawn tractor, 21 hp Briggs and Stratton, model 331877-0869-g5. Was mowing and all was good, pulled into garage and engine started revving at high speed. Have started a few times since, always goes super high rpm, the outside governor arm doesn't move, but I moved it by hand and it slows the rpm's down. Moves freely and everything outside is tight, so I thought the governor gears stripped, possibly. Took it apart, found governor gears look ok, and found this spring in the crankcase, it was a little tangled up but straightened it out. Trying to figure out if this spring goes on the governor or somewhere else, I can only assume it has something to do with the over revving issue. Thanks, Brian
