Blue Moon Mountain Farm
- Oct 3, 2024
- 4
Hello experts. After using my FS 91 for 3 years and being thoroughly satisfied, I made a stupid mistake made in haste. After using a metal brush cutting blade, I changed over to the line trimming head. Later, wanting to reinstall the metal blade, I inserted the anti-rotation pin, hand rotated the head but could not drop the pin to lock out rotation. Debris...no, pin damage...no. Checking the parts for the metal blade, I found that I did not install the thrust plate. This plate has the hole to allow the anti-rotation pin to drop into place.
So now I am seeking advice as to how I may stop drive shaft rotation so that I may unscrew the line trimmer head.
Do I need to open the gear box and block gear rotation, or is there some simpler method?
Thanks
Thanks
