Again those are a fixed speed as in RPM engines. Pull the cord. She revs to say 3500rpm all day long.After sitting for about 10 minutes it would start but would only run slow, never went to full speed.
If you pull the fuel hose off AT the carb inlet, draining a good amount into a glass jar, proves two things. One is the fuel tank cap IS venting proper. Next is the tank, fuel lines and any filter are not clogged up. Tank to carb has proper solid fat fuel flow.Checked the fuel line, getting good flow. Had previously cleaned the tank. Replaced the thermostat on the exhaust with another used one, no change. Think I will give up at this point. Maybe use as a parts mower. Thank you everyone for all the suggestions.
Again, that engine, should operate, at say 3600rpm, all day long.I don't think the linkage is not the problem. It runs fine when it is started when it is cold. The running slow only happens when the motor is warm.
