vrotsos991
- Oct 5, 2015
- 1
- 1
I have a Snapper Series 11 that I purchased as a fixer upper. It has a Briggs 12.5 HP 286707 motor. The motor had the beautify cover taken off, the crankshaft extension was removed and stripped as well.
After further investigation I found that the crankshaft female thread was stripped. This is a 9/16-18 thread. I tried to chase the threads but was unsuccessful. It seems that the material the crank is made out of is to hard to form thread, and the tap kept wanting to go in at an angle.
I need to install a bolt to maintain pressure on the flywheel so that it will not come off obviously. What options do I have since I can not tap this material? Is there a filler that can be used to fill that cavity and then I can drill and tap it to install a bolt? Any ideas?
