What is the compression on a new two cycle string trimmer? What is the lowest compression where it will still run? The compression on mine is 45 psi, trying to determine how much life is left in the old gal
What kind of trimmer is it?What is the compression on a new two cycle string trimmer? What is the lowest compression where it will still run? The compression on mine is 45 psi, trying to determine how much life is left in the old gal
If it still works keep using it until it dies.What is the compression on a new two cycle string trimmer? What is the lowest compression where it will still run? The compression on mine is 45 psi, trying to determine how much life is left in the old gal
Mostly Bull....Getting an accurate secondary pressure reading an small 2 strokes can be very problematic
Compression testers with flexiable connections can expand to a volume substantially bigger than the volume of the combustion chamber
Some times it takes 100 pulls till a compression tester stops going up and that is how you have to do it , just keep on pulling with the trigger wired flat chat till that tester stopd moving
Then post the number .
Using a tester according the instructions ( 6-10 pulls ) will never give an accurate reading on anything under 100cc
