Ric
- May 7, 2010
- 139
- 5,765
Had the same problem with my FS130. I put a new spark plug in and it fired right up but then went back to having to use about 15 pulls to get it going. I put a new carb on it after 10 plus years of use and it fires up every time now within 2-3 pulls. But since yours is a newer model maybe you just need to clean out the carb and lines and put some new fuel in it and see how that works. All this is stuff you can do for free, as Ric says, so try all of that before going to your dealer. Like I stated before it sounds like a fuel system issue you just have to find out which part is the trouble.
Can I ask if your using the primer bulb and priming the unit before you try to start it?
