taxidermist
- Jun 4, 2011
- 112
I have a stihl 110 r 4 mix that will not run.
I have adjusted and decarboned the valves
New carb, new coil, new plug
Piston looks good
screen is clean
It will fire on SF with upper cyl lube. (dont give me the story)
Fires good with my ZAT 4 ing tester
Thank you,
Rob
Piston looks good
screen is clean
Thank you,
Rob
