Fish
- Aug 2, 2013
- 5,145
OK...If you were smart enough to read the IPL, you would see that item #5 IS a self tapping screw...and it mounts the air filter housing to the base. That is the ONLY self tapping screw shown on your IPL...and it is NOT a normal user service screw. However, if you look at ALL the other screws, NONE of them are self tapping, and any screw that might be in a normal user or serviceable position is a 6MM Torx bolt, which mounts into a steel insert in the frame. Your analysis is 99% Wrong.
Torx just designates the driver, has nothing to do with the threads.
