Stihl MS280 Rebuild question Engine lube?
IO_Storm
I've just replaced a cylinder and crank assembly on my Stihl MS280 chainsaw. The old was was scored. When the old one was removed, I cleaned out some oil from the crankcase. Now that the saw is reassembled, I'm wondering if I should have added oil to the crankcase. I can't seem to find any info on this. If I do need to add lube, what type should be used?
Thanks,
IO_Storm
Briana
Hey there - WELCOME to LMF!
I moved your thread to the Stihl Forum. :smile:
noma
Hi IO_storm
So is this a two stroke or 4 stroke? did you put any assembly grease on that when you put it back together? How are you going to get oil in there now if its back together,if its a 4 stroke you got to put oil in it. If it 2 stroke its in with the gas.
taxidermist
No your fine they get lube from the mix in the gas.Do you know why it blew up?
Rob
lakeviewpe
You may want to break the new cylinder in by starting and letting it sit at idle for 5 minutes before you start cutting for about the first five uses.
