Stihl MS250 wont idle
ghost1
Need some help. I'm working on a Stihl MS250 chainsaw that won't idle. I have done the following and not sure what else to check.
Has compression
Replaced carb, and plug
Checked fuel line, impulse line, and intake boot for leaks
Adjusted idle, high and low fuel screws
Both carbs have same symptoms.
BlazNT
Does it run but not idle?
deminin
Check the muffler....the spark suppressor screen can get partially plugged on any chainsaw, especially if you have been running the oil mixture a bit more than recommended.
upupandaway
Excessive leaking shaft seals will also do this.
Shaft seals usually make it hard to start from cold or after a prolonged period of storage .
Then it becomes easier to start when you are using it every weekend ( cutting firewood ).
upupandaway
Bert, the condition I am referring is where there is serious damage to the seal. Slight leaking that you imply where the lower chamber can build enough pressure and still idle. My suggestion damage\wear\worse leak is beyond this and thus not enough lower chamber pressure at idle (die) but enough pressure at high to keep running. Using it more frequently won't fix this condition. Just a suggestion to the user's problem.
BlazNT
We lost the OP a long time ago.
ghost1
UPDATE:
It was the piston/rings. One ring was seized and piston/head was scored. The seal on one side was very loose on shaft. Replaced head, piston, rings and seals. It runs like a new one...
Thanks to all.
