- May 6, 2010
- 51
- 11,390
The soft start accomplished two things, Made it easier for the small people to start the saw and due to changes in timing to meet EPA standards prevents getting the rope ripped out of their hands when the saw kicks back which was very common on the 021-023-025 series saws around 2004. You could cold start the saw without any issues. Run the saw a few minutes and shut it off and then try to restart. About half the time it would pull the handle out of your hands and was told by a half a dozen Stihl dealers that was normal for the new saws without easy start.. Had several customers take their brand new saws back to the dealer and either had them retrofitted to the easy start or had the saws replaced with easy start saws.The soft start saws are designed for whimps who can not overcome the engine compression
The secondary spring spins the engine at exactly the correct speed for starting .
Women or blokes with short ams who do not cause the engine to turn over on a single pull have no problems
Big boofy blokes who nearly rip the starting cord out of the engine every pull are the ones who have problems
Little pulls that may take 3 or 4 till it trips the secondary spring works best .
And as mentioned drop starting will not work.
I have a sneaky feeling that drop starting which is easy to mess up & cut yourself is probably the reason why it was designed
No saw company would make a design change that adds several extra parts unless they have been sued by a smart lawyer representing an idiot .
