Stihl leaf blowe bogging down
sgkent
well,Santa Claus might not be real but the Easter Bunny is. :)
strohmoose
I'll bet that nearly all of you complain about your insurance rates being too high!
appel1978
Well
So you bought one of those "tune up kits" assembled from parts of highly dubious quality.
Then wondered why replacing the Stihl parts with stuff that could have been fished out of the scrap bin the blower does not work properly.
Really ?
If the carb has a H & L needle turn the H in 1/6 a turn at a time ( count them )
As soon as the blower will run at full throttle then turn the L needle in very slowly till the engine starts to faulter then back out till the engine starts to faulter and finally back to a spot 1/2 way between them
After that go back to the H needle & do the same
It's final position should be a little ( 1/12 turn or so ) further out than midway between too rich & too lean .
That fixed the issue thanks for the easy instructions. Running great now
