Ric
- May 7, 2010
- 142
- 5,765
Thanks for the reply Ric, i checked that and it was a bit dirty but even if i left it out it does not even try to go, very strange as its been a very good machine working fine then nothing. Think i will have to put it in a repair place.
Let me ask and this is just a suggestion but does it have a primer bulb? If it does check the thing and see if it's cracked or has a hole in it. I had a trimmer that wouldn't start and I did about everything you have done and found the primer bulb had a crack and after I changed it the trimmer ran great. It's only a suggestion but sometimes we tend to over look the simple things.
