Stihl fs66
Rls8836
I am needing to know the size of string the Stihl fs66 uses. It is a dual line. Also can you buy the gas cap gasket alone or just buy a new gas cap. If I tilt it a little gas drips out of it. Guess I should try a determine if the threads are somewhat damaged. Sometimes a cap will feel tight but are not actually snugged down. Looking at the underside of the gas cap the gasket appears intact.
Welcome to LawnWorld!
We moved your thread to the Stihl forum.
