Mobilman44
- Nov 5, 2018
- 3
Hi,
Last week my faithful Stihl trimmer started right up with the choke engaged, but when I used the throttle it bogged down and stopped. I went thru this a few times, and it continued to bog when I hit the throttle. After a couple of tries, I realized it would continue to run full speed with the choke engaged. So even though I had no throttle control, I managed to trim the front and back yards.
Afterwards, I replaced the plug, checked the spark arrestor (clean) and visually checked the carb. I did notice gas was leaking and the filter was wet.
I "assume" the carb is the problem, but am wondering if its simply a matter of switching out gaskets/membranes or do I need a new carb, or is it time for a new machine?
Your help and comments would be greatly appreciated!
Thank you!
Mobilman44
Thank you!
Mobilman44
