The user manual does not say anything about servicing the gear head, but I run the heck out of this thing. On a prior Sthil I had, the gear set wore out and replacement was over $125 because it was an odd model. Should this be taken apart and cleaned and re-greased periodically? Like I said, I work it hard and sometimes the head ends up under water. I try to avoid this, but it is not always possible.
Thanks!
Thanks!
