miller time
- May 25, 2015
- 1
- 3
Hello, I am new to the site. I have been working on all kinds of small engine equipment for several years now and am usually able to figure out most problems.
I am working on a project now that has got me stumped. I am working on a Stihl 021 chainsaw for a friend. When he brought it to me it would start and run but would quickly overheat. At that time I checked compression (100psi) and it had good spark. I knew that 100 psi was on the low end so I checked the cylinder walls which were ok.
We decided to do a rebuild, my first try at this. I replaced the following parts: piston rings, oil seals, intake and exhaust gaskets, fuel line, and impulse line.
Now the saw will not start, not even fire And the compression is no better. Also I noticed there is no fuel being drawn from the fuel line to the carb when you disconnect it.
Anybody have any ideas?
Thanks
Thanks
