kb05
- Nov 1, 2023
- 3
I have a Stihl BG50 Blower that wants to rip my arm off every time I try to start it.
I researched what might be wrong and everything pointed to a broken woodruff key causing a timing issue, but this search only found info on other small engines with the same symptoms and not this blower engine specifically.
I have since taken it apart and the key appears to be molded as a part of the flywheel. There was a tiny amount of play in the flywheel before it was tightened down so I replaced it. Same amount of play in the new one before testing it again. I don't know if that is normal.
I can get the blower started but I have to have it on the ground and put my weight on it and kind of work in short pulls otherwise it will pull my arm and jerk off the ground.
Any advice is appreciated. Thanks.
