craigtrader
- Jun 17, 2021
- 4
My stihl runs if i prime it through the plug. I cant get the primer bulb to fill. It has new plug clean high octane gas and is stored inside.
When I can get it running it runs good. the primer bulb was replaced + put in by a shop and he was unable to get it to prime or get the primer bulb to fill. Should the carburetor be replaced? I'm some what handy and could probably do that. Im really looking forward to some constructive input. It has spark and all that's needed to run. I'm thinking the main issue is the primer bulb. Im guessing something is probably plugged not allowing proper airflow to the primer bulb.
