Here's what I've done so far: verified that the ignition module/coil is working; verified the start/stop switch is working; installed new plug gapped at .02"; installed new air cleaner; cleaned spark arrestor (it was pretty much pristine even after 9 years of use, thanks to all the operating time at WOT). It has been suggested that the flywheel pulley key may have broken or become dislodged, and the timing has slipped. Is there any way to verify that the key is missing without pulling the pulley? The pulley nut is holding the pulley to the crankshaft tight enough for the starter cord to crank the engine. Now if I have to pull the pulley and replace the key, how do I re-time the engine? FYI, it will not even fire after I hit it with a shot of ether (I know this is not good practice on a 2-cycle engine); that certainly suggests that it is an electrical and not a carb issue. Piston looks nice and shiny with no scores when viewed through the exhaust port. I would certainly like to get it running again, so any suggestions for what to do next would certainly be appreciated.
Thanks
Thanks
