Steering issues 2017 Craftsman Garden Tractor 917.204090
jmachen
Location
SW VA
Posted this on another tractor forum and got no response at all.
Its a 917 source, so made by AYP/Husqvarna to my understanding.
The steering has the turn tight setup. I find when taking tight corners even at low speed the front wheel will stick sideways and just dig into the ground. I just had a wheel fail on it and need to fix the steering for good.
It has maybe 90 hours on it but is out of warranty. I have replaced the wheel bushings and regreased everything trying to reduce the play in the front end. The adjustment for toe is all the way at the end of the range and the wheels still face apart a bit. I'm thinking maybe one of the links is just slightly bent.
Every part has play, each linkage, the pivot plates (triangle links) as well. I'm not sure how to tell how much play is acceptable if any. On a car, no play would be acceptable.
I haven't had much luck asking for help from Sears Parts or Husqvarna. The closest Husqvarna shop is about an hour away.
I just replaced both right and left drag links and tie rods as well as changing wheel bushings out for bearings all by a company called HD Switch found on amazon. Parts seem decent and reduced play a bit but still having the issue with excess steering play and toe-out.
When the front end is lifted the wheels can rotate in/out with quite a bit of play. This ends up from a straight alignment to the wheels pointing out. The pivot plates and sector gear plate both have play as well. I don't see any excess wear on those parts either. I guess I can throw more parts at it unless anyone has any advice to offer.
Also if anyone is familiar, would a Husqvarna garden tractor like TS354D from Lowes for $3699 handle my dozer blade and sleeve hitch attachments and be built to a better standard than the Craftsman? Should I be looking at other brands to replace it?
Below are parts that all seem to have excess slop in them. Part numbers from partsdirect for reference if anyone else is searching for a similar issue.
Thanks,
Original parts
Lawn tractor axle weldment
Part #583512701
This part replaces #436870
Lawn tractor spindle
Part #583512801
This part replaces #436873
Part #583512901
This part replaces #436874
Lawn tractor sector gear plate
Part #583551401
This part replaces #440770
Lawn tractor drag link, left
Part #583513301
This part replaces #436884
Lawn mower drag link, right
Part #597069902
This part replaces #436885
Lawn tractor tie rod
Part #597069702
This part replaces #436887
Lawn tractor pivot bolt
Part #532442147
This part replaces #442147
Lawn tractor pivot plate, right
Part #583561101
This part replaces #441873
Lawn tractor pivot plate, left
Part #583561001
This part replaces #441872
You have discovered the reason I hate the tight turning radius mowers. Any component in the steering system will lead to what you are seeing. And most likely it isn't just one component. Bent drag links, play in the ball joints, play in the steering bushings, bent steering spindles, and even play in the front axle where it connects to the frame can all lead to your issue.
Tires not turning normally means the tread is wore out. You said this has 90 hours so that shouldn't be the case. Proper air inflation should be checked front and rear.
Those exotic Craftsman, Husky, Cub Cadet, Hustler and so on tractors are not the best machines. Every one I've see has a ton of steering play/slop. Wheels look like they are about to fall off.......
