https://www.mowersatjacks.com/Images/simplicity/simplicity-manuals/1694643-manual.pdf
read page 29 carefully, no do not change oil & filter again. use jackstands to get tractor off ground, sit in seat & start engine, operate steering etc. all controls, start at idle & work up to full throttle, be patient & perform this procedure several times, yes you may need a helper to bleed air from system by cracking lines with wrench then tighten back up. let us know how it goes.
