Hello BlazNT. The only plastic on it are the wheels and I am not convinced that they are original as they are differing pattern front to back.
The method of height adjustment suggests early. They are 5 position and selected/locked with a sprung steel lever.
There is a model number on it but as mentioned, Steelfort are not willing to hunt it down. The guy I spoke with has been in their emply for 25 years or so and has no knowledge of the pattern.
The Tecumseh is a two stroke and may be a later replant.
I have not come upon a Tecumseh before, although I have heard of them. I had always associated the name with a mower engine, then I discovered and read of Tecumseh the great Shawnee leader. Impressive!
I agree with you Cashman, it is a great looking mower.
Can the HP be determined on the motor appearance only or will I need to look further?
I'll put up an image of the instructions and controls on the motor
View attachment 37131View attachment 37132
