sofasurfer
I have a Stihl FS66 with the circular saw blade. When I rev it it takes a while to rev. When I try to cut a 1 inch tree the blade barely can get into the wood and easily stops the head from turning. I tried adjusting the carb but I'm not too good at that. I turn the idle to highest rpm and back off till rpm drops a bit then back up to higher rpm. I do the same with high speed screw. When I do I am nervous because the rpms go so high it screams but I do my best up and down and then back up. doesn't seem to help with power. Are the brush cutters really just a gimmick that does not work that well or am I not adjusting it well or is my machine worn out?
I cleaned the air cleaner. I did not look at the screen in the exhaust yet. Will do that tomorrow.
