Hustler Fas Trak Starts then dies.... cleaned battery posts, replaced both spark plugs, Checked fuel filter, Clean but didn't seem to have gas in it either. Took drain plug out of carb, sprayed carb cleaner. noticed fuel line had some debris I don't have a engine manual to fine fuel lines or fuel solenoid if it has one
can't get it to repair shop if I cant drive it up on trailer. ha at this point do I replace all fuel lines.
