re-starting this old thread cause I too am have issue with Lawnboy that runs strong and then stalls and dies----I can baby it at bit at the throttle to keep it going and then ultimately I cant any further and it dies. I have rebuilt the carb with the exception of the needle which looks just fine putting in new gaskets, making sure all holes/ports are clear. I did nothing with the float itself cause it looked good /did not check for proper height but it used to run good so sure the adjustment didn't change. Made sure the air hole in the fuel cap is clear, fuel filter is fine. Now I did have to put a new governor spring on it.
2 weeks ago was running strong after all the above but running too fast and that's when I started playing with the governor adjustment and now I'm back to it stalling out----------wouldn't suspect a governor adjustment could cause stalling. I have the 1 carb screw adjusted to best running.
This is making no sense to me----stalling suggest carb/ no gas ---fuel filter is clear and just not suspecting a float issue. It could be my imagination but thinking when its cold its running longer before stalling and then then when it heats up the stalling becomes more chronic. That might suggest something more electrical, right???????----------------haven't suspected spark plug or coil cause it runs strong when running before the stall. After the stall it will start back up so suspect the coil is OK.
I see one carb adjustment on this F engine with Walbro carb, Is there any other I've missed?????? In the 9/2 post by Engineman he is talking of 2 different adjustments on this F engine-----I see the screw on the outside of the carb in front , where is this other one referred to???????
Any suggestion appreciated------------if reliving this old thread gets no attention I'll post all this again in a new one
