nebragah80
- Jul 5, 2017
- 5
- 6
Have a Scott 42 inch riding mower with a 17hp Briggs. Try to start acts like battery is low, turn over a little, turn over a little and stop, checked voltage in battery, is 12.7. Hook up a charger anyway and most of time it will start after about a 3-5 minute charge. Have replaced the starter last year, the solenoid yesterday. All contacts are clean, wiring is good. Should say every once in a great while it will just start right off. Looking for any suggestion on what to check. Did take battery to local battery dealer to make sure it did not have a problem, checked fine.
